Good Day All,
I now that there are a bunch of threads on cleaning the vinyl in our boats. Our vinyl is getting a bit sticky and I feel it is time to really get down and dirty with it. I have generally used Meguiar's vinyl cleaner followed by 303 but I am not sure what the previous owner has used.
I have really liked the Meguiar's products, but based on what I have read, the TA is the way to go for deep cleaning. I finally found the Totally Awesome product at our local Dollar General and picked up a container. I am curious how you are all using, applying and rinsing off this product.
1: Are you diluting the TA or applying it at full strength? Diluting it for touch ups and full strength for deep cleaning?
2: I have seen recommendation to use a soft brush. Are you putting it in a spray bottle and spraying the vinyl then using the brush or dipping the brush in a container and applying that way?
3: How are you rinsing it off? Using a garden hose and spraying it down, letting the water flow off and on the floor and in to the bilge or are you taking a rag with clean water and removing it that way?
I know this seems like it should be simple. I am working on a 2007 with original interior that is in pretty good condition. I want to make sure that I do what I can to preserve it instead of potentially damage it.
As mentioned above, I intend to follow it up with 303.
Thanks in advance for your help and guidance.
