Any ideas to why just the hard tanks fill but not the bags....nothing at all on both sides. Tige z3 with pro ballast.
Hard tanks fill but not the bags....
Do the hard tanks fill to the point that water exits the vent and drain, yet no water in the sac? Theres basically 3 paths for filling the sac. Main fill line and 2 gravity lines from the top of the tank to the bottom of the sacs.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
when it reaches 100 it shuts off is what you mean right? Or are you saying that it hits 100, you hit fill again and it just never fills the bags....?
If its stopping at 100 and the bags arent full you need to readjust the timers. If you are hitting fill after it reaches 100 and it still isnt filling the bags then their is another problem..Germaine Marine
Sound like the gauge is off of the water if not filling the tank, Even with the sac folded up, the tank will over flow when full. Should be less than 4 minutes to fill the tank, less then 8 to fill both tank and OEM sac.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I would pop the cartridge out of the pump body and make sure its all clear. The timer gauge simply runs off the time the pump is switched on.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
