So my boat is about to go in, unfortunately I live in Central NY aka the land of rain and misery... But to my problem, 2013 R20 last year I kept running out of juice for the stereo system if I was out with it playing for an extended period of time sitting. Usually we'd get some time wake or surfing and it would charge it up fairly decent, but it would often run out at wierd times and was just kinda annoying. My house is like 200 feet from my lift so it's a pain to run an extension cord out there every time. I was wondering if anyone has used a solar charger for when it's on the lift and if it's been effective?
Charging the battery with solar?
Cant speak to the solar thing, cause I have not tried it....but they are available for sure. Just gotta check reviews and make sure you get a good one.
You probably want to test battery to make sure its still fully good since 2013 as that could be part of your issue, I can use my stereo that draws from 2nd battery for a longgggg time before having any issue. The other thing you can do...is add a 3rd battery and run it in parallel with your stereo battery. I actually bought a 3rd to do just that and have had it sitting under observers seat for a while, just havent made the time to hook it up. (you would still need to charge them occasionally tho).
You have a 2 fold problem, each with its own resolution, yet one will likely impact the other.
1) you dont have enough amp/hours battery wise, to fir your needs. This could be an alternator/system charging issue, bad battery or just a battery thats too small for you needs. Resolve this first. Do i have a bad battery? Is the charging system working as it should? Is my house battery large enough to yield enough anchor play time.
2) regardless of #1, you need to have a means of replenishing the battery(s) when the boat is back in its slip. Not a week later right before launching for the new weekend, but the last thing you do before walking away from the boat, is take care of recharging the batteries.
Your usage on the water and the Ah capacity of the house bank is going to impact the need for #2, shore charging. The more you anchor and the larger the amp/hour capacity of the bank, the less the boat will take care, shifting the need to shore charging.
Now we come to the solar charging. Yes, there are solar "chargers" out there. I framed charging because its all relative. I seriously doubt you will be able to do a solar setup that will effectively recharge a dead battery. This is a matter amps output compared to the Ah capacity of the battery. To effectively recharge a dead battery, we need a bulk rate output thats in the 10% or greater range of the battery Ah. So you could be looking a solar charger with a peak output of 8-10 amps. Thats probably going to be a sizable panel. Next, you are going to want a multistage smart charger. You do not want to leave a plugged up, a standard trickle charger delivering a constant output, even if its in the 1A range. You need a units that going to go into a float or idle mode once the battery is recharged.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by TigeFamily View PostCant speak to the solar thing, cause I have not tried it....but they are available for sure. Just gotta check reviews and make sure you get a good one.
Originally posted by chpthril View PostYou have a 2 fold problem, each with its own resolution, yet one will likely impact the other.
Originally posted by Tigenator View PostI noticed it happening towards the end of the summer, so maybe repeated small charges from the alternator wasn't enough to keep up. Yeah I'd still need to charge them which is the problem.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
