2016 rz2 28.5 hours. Seems to run okay but the beep every few seconds will drive you nuts. Have about 3 hours on it this season this happened when I filled it up and started to surf.
I will have to check tomorrow on my handy dandy Indmar DTC sheet, but if memory serves me correctly this is a fault for an O2 sensor. There's four total so cant remember which is which. Will post response for you tomorrow.
I'm sure code will return even if it's cleared. Not causing him any problems besides an annoying beep, and ecm is probably not going into closed loop, or a CL+adapt.
That code is for an o2 sensor. Bank 1 sensor 2. Sensor 2 is downstream of the cat and does not effect operation. it just measures how the cat is performing. Try the code clear that Elevated recommended and get it fixed if it comes back.
It will help to pick up the correct socket. Pretty much a must. Available at any decent auto parts store...as well as the O2 sensor. It is a wideband O2.. should have a blue sheath on wires. Look to see if it has water on the tip of it...if it does your gasket at vband clamp is probably not seated in the right spot. If it's wet it will continue to fail.
ALSO, for everyone with CAT systems on their exhaust, use only the synthetic oil recommended by the manufacturer. We've run into countless O2 failures as a result of people using regular dino oil. The phosphorus content in the oil causes the sensors to fail over a short period of time and it becomes a giant PITA. Good luck!
