Hey all! Hope everyone had a great Memorial weekend!
I recently replaced my fuel filter on my 2007 22VE MP 340 engine. I ended up removing the whole canister from the boat as the filter change wasn't happening with the assembly in the boat. I read a couple threads about it and it was pretty straightforward but I had a helluva time getting the hoses on the bottom to budge so I elected to remove the bottom bolt and drop the plate. After getting everything reassembled and testing it, no fuel leaks
, but unfortunately I'm leaking water from the bottom plate. Anyone had this issue? I thought with pressure on it the rubber disc would seal it back up but no dice. I was thinking I may need a bead of silicone around the edge of the rubber seal before I put the plate back on. Any tips are appreciated!
I'll attach a pic of the spot its leaking from.
