Just to add. My boat is being serviced so I had a loaner RZX 3 and RZX2 to try. Below is the feedback I gave the dealer.
FYI:
My boat(2016 RZX): 100% full. (Including plug n play) Sometimes I drop rear non surf to 85%. 350 lbs lead rear surf side and 150 lead in the front. I also throw an extra bag rear surf side ~250lbs in it and a bag in the front ~250lbs. Surf taps 2. Taps 2-4. Speed 11.4
RZX3. I had 100% full plus 500lb bags in both rear lockers. 350 lead rear surf side. Same taps settings and speed.
(Did not have plugnplay)
RZX2: 100% full plus 500lb bags both rear lockers. 200lbs lead rear surf. 150 lbs lead in the front. Surf taps at 2. Taps at 2-4. Speed 11.6
My boat fully loaded produced the best wake. Great shape, long, tall & a great lip
The RZX3 was pretty similar but was a little softer and had a soft bottom. We pearled our boards more than normal. The boat just needs the extra weight.
RZX2: wet boat-get splashed a lot more.
Surf: very similar wake to mine. Not as long. Originally started with all the lead in the rear and moved 150 to the front and that made a big difference in the length.
Overall for surfing the RZX(3) out surfs the RZX2. The way I surfed them the RZX2 out surfed the the RZX3 but that's just because it needed more weight. Did not and probably will not ski or wake board as the kids really don't have an interest anymore in those sports.
Hope this is helpful.
FYI:
