I am drawing a blank on this. I have the eq with the wet wire 6ch rca cable. How are these suppose to wire into the 3 amps? I have the 2 towers running on splitters to the syndx4 so those are good but after that I'm stuck..... I have the two syndx6s with 808 s and 6 xs650s on one and a set of rev8s and xs12 on the other. Also need advice on how the cross overs and bridges are all suppose to be. Thanks!
3 amp setup with Ws -420sq
So, for those pair of rev-8 towers on the #2 Syn-DX6. You will need to Y the tower output prior to the Y's plugged directly into the Syn-DX4 and run a pair of RCA over to this Syn-DX6 to the chnl 1-4 inputs. You will have to use another pair of splitters at this amp as well.
How those Y'd RCA's are plugged in is important. Almost more important than the x-overs.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Awesome! So total number of y splitters would be 6? Had to read it a dozen times but should be good. Thanks chpthril!Last edited by KyleRass41; 03-03-2017, 04:50 AM.
