2nd Battery
    2nd Battery
    Where is the best place to add a second battery: rear starboard access with the TAPS pump or in the port access with the first battery? Also, where are you mounting the battery selector?
    Mount it next to your battery you have now and mount the switch on the panel in front of the battery box up high and to the port side where it will not get wet.
      Thanks Lee!
