I've tried to search and all I can find is info on wiring a GoPro to Tige Touch 1 and was wondering if anyone had any info on what would be required to wire one into the Tige Touch 2 screen of my 2016 Z3? Thanks in advance!
GoPro wired to Tige Touch 2?
Several forums on this but here is the way I did mine awhile back. Look at post #39 on forum link. Search "gopro" and you will find several other forums if mine isn't the way you want it. Know many others have done similar installs and posted on here. Good luck!
http://www.tigeowners.com/forum/show...ighlight=gopro
Touch 1 - simple plug your rca output into the video 1 position (yellow female RCA input) on the viper (The blue box under the dash). Select "video" on the touch screen.
Touch 2 - Follow from the grey plug at the back of the touch screen to the video 1 (or video 2) plug. There is a pair of heat shrinked cables (both have a red and a grey wire directly out of the grey main plug). That is your input to the touch 2 "video" button.Oh Yeah!
Originally posted by KoolAid View PostTouch 1 - simple plug your rca output into the video 1 position (yellow female RCA input) on the viper (The blue box under the dash). Select "video" on the touch screen.
