I am trying to figure out what height is needed from the waters surface so my RZR will clear the lift canapy and not have to lower the Alpha Z tower. Does anybody know, or does the tower always need to be lowered? Thanks.
Canapy height on lift
The RZR hull doesn't draft much water. Most of the published draft is the underwater gear. I'd measure from the top of the tower to the bottom of the chine(the 90 degree corner where the hull side turns under to the bottom of the hull. The hull doesn't settle into the water much at that point so that will get you pretty close.
