One 12 under the observer seat, and the factory 10.
Liquid Lumens makes a product called the top side light. Its a stream light LED bar that is trimmed out and looks like a flush mount light. It goes under the rub rail... They are insane. Let me know if you ever need something from them. We are a vendor and I get some radical discounts
I just looked at the liquid lumens site, are their underwater leds all solid colors or are there rgb options?
They are coming out with an RGB option it just wont be as bright. When you go to a multicolor light the output drop off is substantial. Given how many times I have been hassled I always recommend people to go all white. Its just less of an issue then running blue or any color for that matter.
The whites or blues are insane.. Below is the blue. That board is not a light up board. It has orange trim and the lights are so bright it made it look glow in the dark with the reflection.
I know this is an older forum but I have my RZX2 done and dialed and used for one season so far and put a ton of leds into it and also I built 2 xxx12 boxes and installed 2 more amps over stock and she def pounds now.
If anyone is looking for custom led badges etc let me know I’ll get them sent over also have in stock custom taps plates for 2014 and older Tige’s with the single ram.
I wish we could get away with this up here! The fun haters would be on your arse in a heartbeat. It looks like so much fun.
Plan a trip down to the owners reunion next year dude and night surf until your legs feel like they are going to fall off, or until you can no longer stay awake....
Germaine Marine
I’m planning on removing my tower and stripping the orange powdercoat. Still debating between black and grey but I’m leaning towards grey on the tower to match the gel coat on the rear of the boat. (My boat is black and grey, white inside) I picked up a set of black and gray chromax Tige’ logos to put on it. I removed the graphics beginning of last season. I’m gonna rock it without any other graphics for a nice clean look. After I get the tower back from powder I’ll rewire it all (top nav light, LED light bar facing forward, dual 6” LEDS facing rear, new tower speakers as well) I built a ported sub box for a new 12” woofer to replace the 10” under my helm. New amp for it as well. I picked up a controller to run all the wet sounds in speaker RGB lights and the 12” RGB led ring I got for the sub in unison.
I also removed the hard rubber Es off my swim deck and have a piece of 3m backed EVA foam to replace it with. I’m debating cutting the swim deck down a bit as well but it’s fiberglass so it may be more work than it’s worth. Maybe just put an inch or two spacer under it to lift it out of the water a bit more.
I’ve got plenty to keep me busy!
Man, I should grab 575 and find a night or 2. We would love to night surf. It’s been the forbidden fruit up here!
