2000 20ci. Ozarks. I want to change the oil and winterize in my driveway. Will the water pump pull antifreeze in a bucket, through a short hose to my fake a lake? M&M18.jpg
Winterize question.
You'd probably be better off taking the hose off the thru-hull and putting it right in the bucket.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Another option is to thread a bilge pump to a water carrier. I put the carrier up on the locker so it has gravity to help it as well. Let your boat idle on the fake a lake until it warms up and opens the thermostat, if not you wont get much antifreeze in the actual block.
https://www.walmart.com/ip/Reliance-...9410-03/872426
https://www.walmart.com/ip/Tsunami-8...utlet/11071186
Originally posted by tower210 View PostSo are there 2 separate passages in the boat where lakewater is pumped on 2000 era boats? Or does the seawater pump lakewater through everything?
If the boat's engine is partial closed cooling, then the block proper does not need drained, but other items do, along with the exhaust manifolds and heat exchange.Last edited by chpthril; 10-01-2016, 08:00 PM.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
