Taps tank
    Taps tank
    Where is the tank to fill
    Fluid for taps and what fluid do you put i it? 2002 2300V?
    ATF and on a 23V id check the STBD aft locker behind the wall access door.
      Ok that is what I thought but wanted to double check, didn't fix it this time though.. The shop filled it while it was in there earlier this year and it worked after that, now we have nothing and its stuck up, which doesn't help the surf wave any.
