I have a 21v with a 4 blade prop 14x18 and to boot 2 of the 4 paddles are bent. I know it is the wrong prop for the boat and have ordered an Acme 525 3 blade. My question is because of wrong prop and being bent will that cause the PP not to hold well. Or could it possibly be my perfect pass. I rec. had the servo motor replaced so I don't believe its the PP. Any help would be greatly appreciated.
Perfect Pass not holding, prop bent?
If the PP sets & Tries to hold, I would replace the prop first, and test the PP again.
Are the engine RPM's increasing while the boat speed stays steady or slows (W/ PP on)? A bent prop could cause enough cavatation that the prop is just 'pushin air'
Hate ya bent one, good luck.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by do420jc
PP holds 80-90% of the time. I do notice the rpm's moving around when PP is on, not alot but does move. It seems to drop when we are going around a corner or turning while towing a rider.
There's always going to be an issue in turns because of the location of the paddle wheel...not much you can do about that.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
PP and Props
It could certainly be the prop. This June I had a Michigan Wheel on my 22i as a temporary fix. It was pitched wrong and as a result I experienced a lot of cavitation out of the hole and on turns. Perfect pass went crazy trying to keep up (I had it set on MPH in wakeboard mode/not RPMs). Changing the prop to an ACME 515 did the trick. Now it tracks within .3 MPH of the setting. I would certainly try the correct prop before messing with perfect pass.
