2016 RZR problems
    2016 RZR problems
    I bought the boat in July and have had some type of issue ever since.
    1. Ongoing problems with the tige touch system. The dealer did a software update which helped the issue but now a month later the tige touch is randomly un responsive and the surf system and speed control is crazy acting. Sometimes the taps 3 doesn't deploy and the speed control is jerky and may run beyond the set speed or may stop short or may surge fast and slow. The touch screen is unresponsive to touch at least 50% of the time on the boat.
    2. The taps 3 plates started separating at the welds. My dealer replaced both sides with the updated version. Looks beefier but not sure how they are gonna work cause the damn tige touch computer is nuts.
    I'm starting to think I bought a dud. It's very frustrating when you buy a high end boat and have constant problems!
    Sounds like you need the software reflashed again.
      You may be within your rights to request a new Tige Touch unit - screen and cpu (if they're separate).
        Tige is not the only boat having problems with the touch screens for sure.
          Lots of boats are problem free, don't settle. Take it and and demand it's correct from top to bottom.
          Germaine Marine
            ^x2
              I drop the boat off with the dealer today, they are gonna see if Tige will send a replacement touch unit. We'll see...
                So Tige sent a new touch unit and finally got out on the water to try it out. All systems seem to be working properly.
                  Nice! Happy for ya!
                  PS Where are you located?
                    Great to hear!
                      I'm located on Tims Ford Lake in middle Tennessee.
                      Hopefully all the bugs are worked out now and my son can start working on tossing the rope.
                        That's a sweet surf wave, what ballast are you running there?
                          Taps set @ 3
                          Taps 3 set @ 5
                          10.8 mph
                          Rear ballast 100%
                          Front ballast 80%
                          2 adults in the boat
