Bags not draining all the way
    So what's the best way to get my bags to drain all the way? Even after cycling the pumps off and on for s couple min on the boat ramp there is still an inch or two in it. Seems like there should be enough in the back to pump
    Anyways, there is always probably 3-5 gallons left.
    I always hit the empty switches again when being pulled out of the water on the trailer. Or, you can do about 15mph, get the nose high and hit them. Never going to get every drop though.
      I installed check valves on the vent lines and also hit empty while on the trailer heading uphill on the boat ramp. The bags suck down like raisins and have less than a gallon left in them.
        So do check valves help with drainage?
          Ok...just did a little reading on check valves. Looks like $60 worth of valves will fix my problem. Thanks all!
          Tige.....please install check valves on future boats.
            They can. However, sac port location can also effect sac draining, to which check valves may not help.
              any pics? you have my attention. mine won't drain all the way or anywhere near even when they are tipped up.
                As a side note, I'm going to need to cross vent as well since I just watch the ballast drain as the boat lists once the TAPS3 engages.
                I'm guessing Tige did not cross vent since it would confuse most people when their port bag begins to drain on the starboard side. Why they did not install check valves is beyond me....unless the restrict flow or something.
                  did the water come from the vent or the drain?
                    Great Idea. Please provide details on the valves you are using if you can.
                      Bakes...
                      Check a few things.. 1- that the drain fitting isnt broken and leaking water, 2-which holes water is coming out of.
                      I just CV the vent lines to help with vent siphoning. I also cross drained. I can let you know the results this weekend.
                      Germaine Marine
                        You can get them from Mike Liquid Audio, or wake makers. The valves are a basic plastic housing flapper 1-1/8 CV . They are roughly 15 bucks a valve if my mind serves me right..
                        Germaine Marine
                          Germaine Marine
                            Germaine Marine
                              I cross vented my rear bags on my 2016 Z3 this helped tremendously I still get a little bit of drainage but nothing like before...I think I can reroute the hoses a little bit more to help eliminate it even more.
