Anyone ever use the LED strip lighting for their boats and had a problem? I got some off amazon for less than 12 dollars. I wired them in parallel to my inboard lights.. also ordered some LEDs to replace the old halogen style bulbs you currently see in the photo.. Looks like these things draw up to 1.5 Amps and 24 watts... Will it be an issue the way I wired them would it? If not.. I am going to put some in the bow tonight.. They were so inexpensive if they only lasted the reunion I would be okay with that..Just don't want them to kill the battery but when I had them on and watched the voltage drop it went from 12.4 to 12.2 Volts so I figured I was okay. It was a simple install and I can easily take them out. Def not permanent by any means as I want to do a much better install job once I learn more about the lighting and how to wire them correctly. This was just to see how they would look/function and to test out at the reunion hopefully.
