So I went to change my transmission fluid (Indmar V) and the dipstick said it was way high. Thing is, this is how it came from the factory. Prior owner had not changed any fluids or done the 20 hr service yet (hrs are in the low 20s)
Easily an inch or 2 above the full line. So I took out a quart and a half of fluid. Checked the dipstick and it was dry. I put in a quart and it's still easily 3/4 inch to an inch above the line. Fluid is cold
So, that said, should I take out some fluid until it is just at the full line? The dipstick has a pretty short distance from add to full ( about 1/2 inch). Boat is pretty level sitting in my garage.
