Hey all,
I purchased a slightly used 2013 Tige R20 this Spring. I live in Maine so my season is a bit shorter than normal. I like the boat but am having some very frustrating issues. First off, had a problem today where the boat wouldn't start. Checked everything...my friend took the starter relay out, shook it, and it finally started. Should I just replace it? Not even sure that was the issue but it worked. No clicking...nothing. The second and perhaps most frustrating issue is that when the boat goes over 30, it porpoises like crazy. I adjust the taps all the way down...to no avail. Understandably, the family doesn't like riding in it over 30. In full disclosure, I did hit the prop/shaft this spring and did change the stock prop out by recommendation of nettleprops. Not sure if this is the reason for it?
I'd bring it to the shop but the closest dealer is in NH.
Thanks in advance,
Z
Thanks in advance,
Z
