Hello TO's,
I've given my dealer two cracks at this with no luck. I'm hoping the community here has some ideas.
As you likely have seen, I've been experimenting this year with my 2013 Z1 (PCM 343, 1433 prop, Wake9 bags). I've been trying different combinations of gates and tabs to see if I can refine my surf wave which is already pretty good.
Starting early this spring I noticed a bad vibration when fully sacked. It started the first time at the Alberta TO reunion at Little Bow. I tried weighting both sides of the boat and using a wedge from AJ. The boat started vibrating furiously. It shook the swim platform and even shook the mirror. It shook so bad it threw an engine code.
Now I've experienced cavitation before, but this seemed to be far more violent than that. In the end, we reduce the ballast and surfed anyways. I took the boat to the dealer and they diagnosed a misfire from the code. As such, they swapped the distributor cap. (which reminds me, PCM still hasn't given me warranty on that).
I went out again and immediately it did the same thing. This time with just normal listing. It was particularly bad listed to starboard. Threw another code. I took it back to the dealer again. They said bad alignment. In fact they said "extremely bad alignment". So they fixed it up again. (BTW - your prop should be able to spin if you grab it with your hand and apply a reasonable amount of force. Mine would not spin prior to the alignment)
The dealer lake tested it again and pronounced it fine.
This weekend I took it out again. With full ballast port ballast and my suck gate, the boat struggled to get beyond 10 MPH without the violent shuddering. Putting TAPS down a bit would help, but as soon as I would raise TAPS (nose higher), the shudder would return. In the end it threw another code.
So here I sit. The boat is nearing the end of its Tige 360 warranty and I want this fixed before that happens. However the dealer doesn't seem to know what to do. Is this simply a cavitation problem? Can cavitation hit you so hard it throws a knock sensor code??
I am perplexed and looking for help.
Here is a video I created from one of the worst runs. Rider is 6'8", 300+, so he typically caused it more than the rest of us.
https://youtu.be/xXEi44cllcU
