I have a strange problem. When we were tubing yesterday I would slam the boat into neutral and the engine would die. It doesn't happen when I surf because I gently go into neutral. Could this be a inertia switch, or maybe starving the fuel pump for a second when the gas isn't full or? Any ideas? Thanks guys!
Engine shuts off question
Originally posted by UNSTUCK View PostI wonder if you IAC motor is having trouble adjusting quickly. This could be due to dirt. I'd look in the intake and clean it all out. This is at least a good place to start and will only cost a can of brake clean.!
