Last weekend while idling through 5 mph zone on the way to dock we hit a rock. Engine shut off but started back up ok. Took it for a drive and had pretty bad vibration. At first look I didn't see any dings or bends, but when I got home I started turning the prop and shaft and found one blade that looks completely off. I am assuming they are all supposed to be uniform in distance and pattern when turned? In the picture three of the four blades follow the same line along the wood. You can see the fourth. Bent correct?
I checked the prop shaft and rotated it against a straight edge and no apparent bends. I did notice though that after the strut the wear pattern looks a little different. I don't know if it's always been like this or not? Is it possible the shaft moved back?
Thanks for the help!
Sent from my SAMSUNG-SM-G900A using Tapatalk
