I have a new Rzr and the first several times out no water would drain. I started leaving the plug in unless I use the cooler during the day then I remove the drain on boat ramp and little water runs out. Today did a little surfing and when I pulled the boat out of the water I removed the plug and water drained for 5 mins. That more than usual. Normally no water drains unless ice melts in the cooler.
