Mission Delta on 2012 Tige RZ2
I've posted a lot about this in other threads. I made my own the second I saw Missions pre-release photos. To date I think it's the closest DIY knock off to the mission version I've seen yet so I doubt it works much different. After seeing what others have made work I probably put more effort into it then needed. But it works and I personally have had great success with it on 3 different boats. On my RZ2 I have run with and without bow weight. Often because I'm too lazy to manually fill my front sac(s) and it works fine either way. Defiantly get more length using bow weight. I attach it forward as low to the bottom of the boat (below the step in the hull) and as close to the transom as I can get. Speed set to 11.2.
I have two 1100lb sacs in the rear and fully filled I could not get over 9.1mph. At one point I got myself stuck in limp mode and thought I broke something. Solution was to fold over the legs of my bags and skate back to about 800lbs on each side. Bonus, I increased my storage under my seats.
I even cut my cooler out to Increase the list on the goofy side a week before I discovered the idea of a suck gate. A Lot of work I didn't need to do. It's ok that thing never held ice anyway and I welcome the storage.
Some of the new designs are offering some adjustability and after analyzing how sort gate works, having a plate that's has more of an angle on it may work better. My buddies have made more of a wedge style suc gate and while I have not tried those on my RZ2, they work really well on there boats.
Check out Quick Shift Wake Surfing on Facebook. Really like where this guy is going with this and while I can make
One that works for $40, ide consider one of is.
Ide like to run a little more weight and I'm looking for a new prop. Not sure if I should go with the Acme 1433 or the 1617. Leaning towards the 1617 but would appreciate any opinions or advice a stone has on props for the RZ2 with a 340 HP Marine Power motor.
