Height Help!
    Height Help!
    I have a 2005 22V that sits on an extreme trailer. Can anyone out there tell me what the height is with the tower up. on the trailer from ground to top.
    Thanks!
    My 20i won't fit through a 10' tall door with the tower up. It is about 1.5" too tall.
    Hope that helps.
      My 06 22ve sits on a Dorsey trailer, It stands about 10.5 ft to the top of the light on the tower.
      Might be close to yours, give or take a couple of in's.
        thanks for the help I wish I kenw for sure though.
          My 05 24V should be the same height as yours and the same metcraft tower I believe. It measure 10 feet and about 6 inches.
          I ought to measure the tower alone and see if you could get it in a 10 foot garage if you remove the board racks. If you don't have access to your boat, post again and I will go out and measure it tomorrow for you.
          Be excellent to one another.
            oops my bad I didnt say what tower I have.
            I have the tige tower. thanks for all the help. I was thinking it was closer to 12. so I can fit it in the garage no problem
