Gauge trim rings (Bezels)
    I'm assuming the gauges in my 08 22VE are Faria.
    Both of my large gauge bezels the chrome is beginning to bubble and appears to be on the cusp of flaking.
    Does anyone know where I can source new bezels?
    I'd prefer to replace with something that uses a billet anodized aluminum -vs- the chrome plated plastic.
    Something similar to what the offshore powerboats run.
    I.e.
    Rex Marine
    Hardin
    Etc.
    Anyone have experience with this retrofit?
    I had the same issue, decided to just plasti dip them, looks okay, could probably use another layer.
    Would like to know if there is a better alternative though, e.g. replacing as you mentioned. Can the bezels be removed or would you have to replace the entire gauge?
      I have the same problem, mine have already started flaking. It would be great to find a replacement.
        You can send them toFaria for a rebuild.
          Can you take some photos? My faria are swaged Stainless Steel so I'm wondering what you have!
          Sent from my HTC 10 using Tapatalk
            Has anyone found a solution to this issue?
