I picked up a 09 RZ2 with the Alpha tower. It has the flip over pylon with light. First day out the Nav light worked fine, the second day it quit. So I pulled it apart to check the bulb, no dice. There is a shorted wire in the tower. Is there a way to remove the housing so I can run a new wire?
Tower Nav light problem
Given how the light/tow point swivels, id look real close for the open to be at the point. There is a removable cover on the top side of the tower to gain access to the racewayMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostGiven how the light/tow point swivels, id look real close for the open to be at the point. There is a removable cover on the top side of the tower to gain access to the raceway
I feel like a fool for not seeing that cover. Guess I should have folded the Bimini up before I started digging into it.
