I'm looking at a 2015 ASR with the AVX surf system with the goal of using it primarily as a surf boat in water that is approximately 10-12 feet deep. My question is will this boat produce a wave that is as good as the RZX or Z3? This boat has been discounted but is new and I like it but I see a number of reviews stating that it is a wakeboard boat and not a surf boat. The AVX surf system would lead me to believe its a surf boat, but I don't want to make a costly mistake and I can't determine its true surf ability on a demo. Thank you for any help
Will an ASR produce a wave that is as good as the RZX or Z3
I've seen pics on here from member "loudelectronics" or such and he had a phenomenal wave behind an ASR. Might do some research on his post and perhaps he will chime in at some point. Most dealers aren't going to have the weight setup like his but at least do a test on it and spend lots of time testing it.
If you are looking at the white ASR at Sun Marine in Lake Havasu (also showing online in Ontario, CA),you might want to check that boat over in detail. It is advertised as having AVX, but it does NOT have the AVX system on it. Whoever owned it previously installed a couple of extra trim tabs (not Taps 3 either). Just a heads up if that's the boat you are considering.Last edited by D&P Powell; 06-27-2016, 12:50 PM.
Originally posted by D&P Powell View PostIf you are looking at the white ASR at Sun Marine in Lake Havasu (also showing online in Ontario, CA),you might want to check that boat over in detail. It is advertised as having AVX, but it does NOT have the AVX system on it. Whoever owned it previously installed a couple of extra trim tabs (not Taps 3 either). Just a heads up if that's the boat you are considering.
X2 definitely not AVX.
Originally posted by skibumsd View PostNo it wont. Stock they where not comparable. If you put more money in to the asr it gets better but still not close to the rzx with the taps 3 on it.
@SurfR check out posting #8 on this post this is the one I was talking about
http://www.tigeowners.com/forum/show...ud+electronics
Originally posted by SurfR View PostThis boat is a demo and priced well below market price.
