My ongoing sage trying to get boat out of limp mode. ECM reporting two throttle position error codes. We have changed sensor. We have calibrated sensor to make sure initial voltage coming from sensor on power on is between parameters (0.95v-1.0v.) Mine is set at 0.975 volts.
ECM will not stop reporting errors. Can't clear the codes. Talked Eddie Albright himself - the inventor of the MarinePower. He sent us the flash codes to completely re-flash the ECM. Did that. Same error codes that cannot be cleared.
Both mechanic and I completely at a loss. ECM appears to be working as it talks to computer and reports everything as it should. Problem is I can't order and ECM then if that is not the problem return it.
Almost in tears as boating season is here and I have no boat.
