Can a throttle potentiometer be manually calibrated?
What's the part number of the throttle body you replaced?
Thanks
I honestly have no idea. Call Marine Power. They are very helpful. Hopefully they have one left if that's the part you need. You just need the serial number from your engine.
2008 Tige Z1 Limited Ronix Edition
360 hp, Fly High ballast, Alpine, JL Audio, Kicker, Wetsounds audio
I am experiencing the same symptoms in my boat (2006 22ve). I've read a number of threads that mention testing voltage of the Pot from the back side of the connector while it's plugged in. After jamming my multimeter in the back of the connector, I was unable to get any readings. Did you have to do something similar to test your voltages? I have a new pot sitting in my garage but would like to see if I could calibrate my existing one first.
My 06 Ve kept going into limp mode until I replaced the pot behind the throttle lever. Make sure the ignition is on with the engine off before you take readings. It’s tight back there so it is difficult to make sure the multi meter leads are making good contact. It’s been a couple years but I think the bad pot I replaced wasn’t reading any voltage.
Thanks,
Gratrix14
gratrix14,
Did you happen to get this resolved? I am having a similar issue.
Thanks
Thanks,
Gratrix14
gratrix14,
Thanks
Unfold paper clips and stick them through the back side of the harness connectors then attach your alligator clips to the paper clips. Try not to poke holes your wiring for testing. It allows a place for corrosion to begin. On these wires where a tenth of a volt can really affect your engine performance, you don’t want any corrosion.
I spoke with Marine Power and they sent me the attached instructions for Throttle Calibration. I have tested the wires at the POT by the throttle lever and also at the TAC module back by the motor, neither register any voyage. Maybe it will only register while the boat is running? Anyway, I am going to make another attempt with the dealership to see if they can figure it out.
