Aux Plugs on 2008 22ve
    Today I plugged my Tsunami pump to drain my fat sacs and all my aux plugs went dead. I checked the circuit panel and none of the circuits where popped. Any ideas on what to check?
    Jerry
    The power outlets on the dash? Did you check breakers or fuses ? Sometimes those fuses get corrosion on them and stop working. Pull it out and replace it id say.
      The three on the dash as well as the one in the rear. I check the circuit breaker panel to make sure they weren't popped out. Where are the fuses?
      Jerry
        Check up under the helm behind the steering wheel. Their will be black covers with connectors that cover the fuses. Should be wire tied into the harness..
          Thank you. I will check.
