Want to hook up Sirius xm on our 16 RZ2 with TT2 and Polk audio. Has anyone installed the tuner to do so and if so what did you guys buy and how did you do it? Thanks!
Receiver installation is easy, but I would suggest a better antenna then what comes with the kit.
I bought an Onyx receiver and car kit. I just plug the power in the glove box and plug the aux out cable into the aux in plug in the glove box.
The auxiliary cable produces better sound than using the FM broadcast.
I just set the antenna on the passenger dash, but like chpthril mentioned, you might consider a different antenna. My sunshade seems to book the signal every so often.
There's probably a better way to do it, but this is simple and keeps the receiver protected in the glove box.
