because if you do you might buy one.
I just got off the water doing a demo of the RZ2 and it is the boat I am going to buy. It handles great and the ride was very good over the rollers and chop. It is a very roomy boat and the bow area is great as well. The new speed set is awesome. You turn on the speed set, set the speed to what you want and then go. As you go it tells you if you need more throttle to reach the speed. No more looking for the light. Tap the speed set and it goes up .2 mph, hold it down it goes up 1 mph. Big improvement over the 06 version. The gages are very easy to read and give you more info then you know what to do with. On the main Display you get Voltage, Engine Temp, Depth, and Oil Pressure. On the side displays you get air temp, water temp, depth, oil press, engine temp, and volts. When you turn on the speed set the middle display has actual mph and your set speed.
The boat will be at the blue water reunion leaving today. It looks awesome with the Xplosion tower with the Monocoque (I think that is how you spell it) upright. Zany took a pic of it in the gallery. The only draw back is the bimini. It is a 10' (which is what I want), but getting it up is a bit of a hassle (but easy enough to over look), but well worth it when it is up. Tige has hit a home run with this boat!
