2015 Tige R20 Taps 3 Retrofited
Tigé Junkie
- May 2013
- 920
- Central MN
Another question...how are you controlling the TAPS3 without TigeTouch? Do they have a "manual" control option? If so, would you please post a picture?
Thanks"I think I am pretty smart for an idiot"
N3vrsat1fied - thanks for the weight info, will start there.
Bjax- all parts were ordered and retrofit was completed by my local Tige dealer Germaine Marine.
zany- it appears that the platform was built up/reinforced where the actuator mounts were mounted. Not sure how the lift of the platform will be, hoping the actuators will actually make it more sturdy that before (was sloppy). Don't believe there will be much more if not less on the pins.
Z3co23 - thanks
Unlike AVX which requires the Murphy control touch screen, you could add TAPS 3 to any boat with the switches.
I am surprised, actually downright SHOCKED, Tige is allowing this with their history of not allowing anything to be backwards compatible.
It took some time to figure out weight and taps position, but now the wave is as good or better with as much or more push. Don't have any pictures at the time, will take some next time out. It also make the boat fell much bigger, we don't flood the boat with big waves when surfing (usually happened a couple times a day) and rough water is no longer rough. That alone is worth it.
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
Originally posted by boardman74 View PostUnlike AVX which requires the Murphy control touch screen, you could add TAPS 3 to any boat with the switches.
I am surprised, actually downright SHOCKED, Tige is allowing this with their history of not allowing anything to be backwards compatible.Be excellent to one another.
Originally posted by talltigeguy View PostIt wouldn't surprise me if Germaine just back engineered the tabs and put their own lenco actuators on there without talking to Tige about it.
Sent from my SAMSUNG-SM-G930A using Tapatalk2015 Tigé R20
