Anyone else with an 2015 r20 experiencing or have experienced this problem ? have not tried each pump separate to see which one is doing it but will hopefully be getting a chance to see today or tomorrow.
r20 Ballast pump circuit keep popping fuse/circuit breaker
Mine does the same thing. But only if I run all 4 pumps at the same time. Not a big deal because that 400# nose sack fills pretty quick. I never dug into it any deeper than using 3 pumps at a given time. They haven't flipped since.
Sent from my SAMSUNG-SM-G930A using Tapatalk2015 Tigé R20
One breaker for all ballast pumps What size is the breaker?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I found this post because I tripped the breaker on my R20. You mention above subwoofer. I don't believe I have that option. I cannot find any circuit breakers under my dash. I do find 2 10 amp fuses. Both seem fine. Any other thoughts as to where the breakers might be? I find reference to them in the owner's manual, but it just says "under the dash". I guess that's not specific enough for me!
I think there is a removable cover/wall that will expose what you are looking for.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Should be able to run all 4 at once. Whats the amperage of the breaker thats tripping?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
