The title pretty much says it. This will be my first summer with my 24V and we went out to try and surf with it for the first time a couple of weekends ago. I was not able to get enough push to let go of the rope. I also think that my brother isn't a very competent driver hahaha (since it was the first time trying to surf and the water was rough).
Here is a video: https://www.youtube.com/watch?v=BpWn...ature=youtu.be
The weight I have:
1 750# sac
2 400# sac
The set up I tried:
750 in the surf side locker
400 on seat (surf side)
400 in bow (surf side)
3 people in boat - all sitting on the surf side
Speed - we tried everything from 10-12 mph
I know that many of you run a lot more weight but this is all I have at the moment. Is this enough weight to make a ridable wave (I think it should be)? Should I put the bow weight in the back as well? Where should I start my taps out at? Also, should the driver be driving in a big circle (turning which way - toward surf side or away?)
I need to get this dialed in at least a little bit so I can be prepared for Lake Mead.
Thank you for the help!
The weight I have:
1 750# sac
2 400# sac
The set up I tried:
