Originally posted by talltigeguy
View Post
Finally got our new boat out
BABz - babzusa.com
Austin, TX
Originally posted by talltigeguy View PostI think if I understand what you are saying the drain fitting on your boat is an inch or two above the bottom of the sack, so it never quite empties that last little bit.
The drain hose SHOULD be on the bottom rear of the sack. If it is on the top of the sack, then I would be surprised if it drains at all.
If your drain hose is coming off of the top of the sack, then I consider that a problem. Aerator pumps like these have their advantages and disadvantages. One disadvantage is that they can never get every last drop out, and create a suction like an impeller style pump can do. 20 pounds of water in the sack is not a big deal compared to your 5,000 pound boat. Unless I were transporting it to another state where an inspection is going to happen, or winterizing, I would not worry.
Tige didn't put quick connects on the sack from the factory?
