Has anyone used this product? Ronix Eight 3 Telescoping Ballast Bag? The red top pops up so you can drop a pump into it and drain it quickly. It shows it being used with the Ronix pump..3700 GPH.
Unless Ronix has made some revisions lately, these sacs were limited in threaded ports, making them less than ideal for plumbing in.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by skivt View PostHas anyone used this product? Ronix Eight 3 Telescoping Ballast Bag? The red top pops up so you can drop a pump into it and drain it quickly. It shows it being used with the Ronix pump..3700 GPH.
WORK AROUND - So what i do is pull the telescoping portion of the bag up and out and leave the zipper cracked to vent the bag. Then fill the bags to the bottom of the telescope and zip it shut. The trapped air in the telescope keeps it above the water level.
CAUTION - Make sure you read the specs on the pumps because i think the 3700GPH pumps were only good on 2012's or newer. However, mine is a 2001 21V and i run them directly from the battery and it works fine. The first time i ran it off the boats 12v system and melted the fuse. Regardless, after filling the three bags the outlet on the pump was SO HOT i burned myself
PERFORMANCE - They fill fast. However, in my setup, i was filling them by myself and i had to move all the gear out of each rear locker while i filled them. By the time i was finished filling them it was problably 6's versus a plumbed system. if you had a partner that could help fill it would go much faster.
This has been a good system in the interim and at potentially a reduced price compared to a plumbed system. However, on my next boat i will be looking for a plumbed system.
