Thanks for all your work on this. Can't wait to get our panel fixed finally. In regards to the spacers do you have some general guidelines to follow on which panels needed spacers vs which didn't. Maybe it was based on the year of the original panel? Some pointers on that would be helpful too. Thanks again.
Tige TouchPad Upgrade Project Thread
Tigé Jedi
- Jul 2010
- 4302
- TN USA
The solution is to increase the distance between the elastomer and the snapdomes, so that when you remove your finger there is enough distance that the relaxed elastomer and the snapdome to always let the snapdome de-actuate. From our experience, we believe most installs won't need any spacers at all. But a few might need one, and we've seen at least one that required two for reliable operation. So we ship two with every unit.
Here's how we determine the proper number of spacers: Install the new panel in the bezel and tighten the four screws (snug, but don't crush them). Confirm that the center snapdome noticeably clicks AND releases when you push and release it. (You can both hear and feel it, thanks to the improved snapdomes we specified.) For the side "buttons", there are three snapdomes... first confirm that each one can be actuated and released alone. Then hold down one at a time and make certain the other two still separately actuate and release (i.e. holding down one doesn't hold down either of the other two). The idea is that all three snapdomes in each side "button" operate independently.
If any of the above tests fail, remove the four screws and add a spacer between the elastomer and the PCB. Reassemble and test again. Add the second spacer if really necessary... and with both you may need the extra long screws we included. Don't overtighten the screws, they are tightening into plastic and you could strip it out.
We'd appreciate hearing back about how many spacers everyone ends up using. Just more information for the database!
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by deva5610 View PostI'm going to hazard a guess that was mine. (NY, 11413?)
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by skyski_tige View PostDo you have any extra Tige Touchpads left?
We have also asked our assembly house if they can assemble any more units with extra/overage parts left from production. Generally when you do a build, you over-order components in case some are damaged during assembly, etc. We may get a few more out of that. Those and all future units will be at the higher price mentioned earlier in this thread.
If you (or anyone else) would like to be placed on the waiting list, please send me a PM with your name and email address and we'll keep you informed.
Thanks!
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Quick question: Does anyone really need an installation video? Things are crazy here and we haven't had time to make even a really simple one. We can do it if necessary, but we think installation is straightforward enough that it may not be necessary in the short term.
Please let us know. We want to be responsive but saving the time right now would really help a lot. Thanks!
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Another wave of upgraded panels shipped today... this covers some folks on the original list who didn't get their paperwork here quite as quickly. The US destinations should see them Saturday (still in time for July 4th), the international destinations shortly after that.
FYI: Based on emails we've received, we asked if any extra panels could be built up by the assembly house from their "overage" parts. They've come through with exactly five extras. We've already had a couple of inquiries, and if anyone else missed the first production run we can ship these on a first-come, first-served basis. Then we're done with these panels until Fall or Spring.
Thanks!
Installed my panel today. Works perfectly. Sets well and up and down seems to adjust about 1/2 MPH per push. I used one spacer. Thanks to everyone who worked on this! It is a great update to a problem area for my boat, a 2006 22V.
I don't see a need for a video. It is all straightforward and easy to do.
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Excellent, thanks for the feedback. We'll hold off on the video unless someone really needs it (and even then, a short phone call may clear things up quickly).
Anyone else install their panels yet? We'd love to hear how many spacers you used, for example. Useful for future production runs.
Thanks!
