GoPro HardWiring Project
    Doing some digging on the old eBay and came across this: image.jpg.
    This should work right?
    That's for power only, right? Are you just going to use a large memory card card and change it out as needed?
    This doesn't look compatible with a waterproof case. Conversely, I've seen right angle power plugs on a ribbon cable, so you can still use a case.
    Let us know what you end up doing. I'm interested!
      I've always wanted to try one of these...
      Switronix DVGP4USBC GoPro 4 Battery Eliminator USB Power Cable, 10-Feet with Backdoor Case (Black) https://www.amazon.com/dp/B0010GW3YO..._tJP2wb5DEZ33N
