Having a vent or pull out hot tube in the walkway is very common
Is this a stupid idea?
I have a circ pump at heater crafts recommendation because it's tough to install the core lower than the antifreeze reservoir. The pump solves that problem plus you get low idle heat. I also have one of the pricey heater blankets from bakes. Everyone LOVES the blanket. The heater tube plugs in and fills between two layers hot air. Works VERY well. A buddy made his own and it works well too.
Sent from my iPhone using TapatalkMods: MLA BIG Ballast System (1800+ Custom sacs, 2 500 W705 sacs under bow), Duffy Surf Flap Mod, Trimmed Swim Deck, Top-Mount Starter
I installed one on my 22v that was plumbed in to the hot water off the engine and it didnt heat very well at idle. if you go the engine going like surf speed rpm it did fine. On that application i would recommend a circulating pump. The rz4 i have now has a closed cooling system on the engine and the 3 port heater is plumbed in to the antifreeze without a circulating pump. It does much better heating at idle so i would say its not necessary. My heater is in front of the driver 2/3 of the way up so its higher than the engine but still heats great at idle.
I have two pullouts in the walk way then two under the drivers kick panel. One pullout and one is fixed. They work awesome, even at idle. I have a 180 degree thermostat though and the Y attachment into the hoses. I think it pulls better with the Y. The heater is one of the greatest mods you can do to a boat. At least when it's cold at night or early season.Build thread: http://www.tigeowners.com/forum/showthread.php?14787-Duffy-s-2005-24v-wakesurfing-mod-thread&highlight=duffys+24v
Originally posted by alwayssummer View PostSo getting ready for the upcoming season the CFO has decided we need a heater this year. Searching through the forums over on TMC I saw something very interesting. There was a thread about adding seat heaters to your boat. No one actually did it to my knowledge but I know the newer boats have them as an option. In the thread there was a link to this http://www.aptuned.com/250-1870. Easy enough, right?
So my question, I guess, is would seat heaters be a good replacement for the standard heater? I like the idea of not having to have the engine running but I wonder how fast four of them going at once would kill the battery. Anybody have seat heaters?
