Has anyone added a drain plug to the hull of your Tige? My 2002 2100v has an off center drain plug which is worthless. I don't trailer my boat so a steep hill is not an option. I was hoping someone could tell me what works; center of stern or center (under) the hull.
2100V center drain plug
Added a center drain and while I was at it, I added a secondary rear drain plug which also serves as location for a Diablo boat drain plug light. ImageUploadedByTapatalk1458696324.698518.jpgImageUploadedByTapatalk1458696343.210329.jpgImageUploadedByTapatalk1458696357.800965.jpgImageUploadedByTapatalk1458696371.340899.jpg
Hopefully with that new center drain, you wont have ever remove the plug lights.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Yeah I got it covered, you guys gave me enough information to figure out how to do this. It's located on the flat portion of the hull, as far forward as possible so the T-handle plug clears the V-Drive. With the new plug I shouldn't have to remove the boat plug lights, I'll even route the oil drain hose out of the center plug. Done!
