04 22V Rocker Switches
    Hey newb here got a 22V today and the rocker switches are faded out anyone have a picture so I know what they are? Thanks.
    Here is a pic of my '05, not sure if they are the same. I think Bakes has them available. http://www.bakesmarine.com/
      I have a 2004 22v. I'll try to get over to storage in the next couple of days.
        Thanks guys!! Is the 04 and 05 the same?
          I had some custom rocker switches made from these guys and they are way cool.
          https://www.otrattw.net/
          Be excellent to one another.
            yep, if the actual switch is functional, these guys can do the labeled actuators for you. They have a on of standard ones, will do custom text edits to existing standard actuators as well as your own custom stuff. They do my ballast switch actuators as well as I just order 16 friday that are a mix of standard and custom text for a 32' center console that im redoing the helm on.
              I actually have OTRATTW saved in my bookmarks also for some off road switches I was looking at a couple years ago. Are the switch tops/rockers universal to most switches or do they only mate with certain switch bodies? Which style rocker would be needed to replace the switches in the above pic? The Contura V line?
                Most marine build use the same witch body, so yes, most of the actuator styles are universal. However, OTR cant etch all he different actuator styles. So if a boat has a style they cant do, its worth it to upgrade all them to a new style.
                  That's good to know. All my switches are fine, but I might like to switch some out. For instance, I have my interior LEDs wired to my accessories switch... Be cool if it said interior LEDs
                      Thanks for all the help!
                          Thanks!
                            OldWaterDawg I send you a PM.
