Ballast bags Removal in 2015 Z3
    Quick question. I would like to take my rear sacs out of the boat for the winter. Let everything dry out.
    Do I need to remove from the hose or can I remove the fitting on the bag?
    I would like to keep the nice heat shrink sleeve on the hose connections if possible.
    You will have to cut the heat shrink, remove the clamp and hose. Those fittings are part of the sac.
