So I just bought a new RZX. The dealer installed an acme 2419 Prop at the direction of the factory. The boat gets up outa the hole very well and performs well whether surfing or wake boarding. My only complaint would be the lack of top speed or rather the high rpm at cruising speed. Also, I noticed it goes through gas like you wouldn't believe (compared to my previous 2013 z1 w/ PCM 409.) Are there any other people out there with the same boat running a different prop? If so, I would be curious to know your thoughts and/or experience with your different prop size. I'm looking for a prop that is better on gas consumption without sacrificing too much performance.
2016 RZX Prop choice??
You will run a lot more fuel if that has the 575. Might try a 2247 or 2249 prop which will give you plenty of hole shot and 3-4mph more top end. I have a buddy with a G25 and 575 and he runs a 2247 and the thing still has crazy hole shot and top end around 40mph if that helps. It would me a little more weight then your RZX so a good comparison.
Darren,
Do you know what the original prop was?
Original top speed
current top speed
original rpm
current rpm
AVX or TAPS-3?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
The engine is an Indmar 575 Supercharged. The current prop is what the dealer put on it by factory recommendation. They said the boat was shipped w/o a prop on it and they install them at the dealer once the boat arrives.
As JLG recommended, I have seen many similar size boats of a different brand with the same engine run the 2249. I think that will get me closer to what I'm searching for, but I wanted to see if any other RZX owners are running anything else.... The same... Or what?? Just trying to make an informed decision before I have to sell a child to finance a new piece of metal, or prop... Ha j/k
Originally posted by DarrenBergmann View PostOh... And it does have the Taps 3.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by Cooter View PostMy RZX3 has a 3077 17x15.5 on it. About 4200 lbs of ballast, he said it would give me more out of the hole, but hurt my top end. Forgive my ignorance on prop selection.....this is my first boat ��
No, props usually do not break. Rather they seem find ground, get bent out of shape. A spare prop can save a trip. Think about those that plan a week long trip to big water like powell and you are 2 hours ride from the nearest ramp.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by Cooter View PostYeah, I knew about the shaft size. Not trying to hi-jack this thread, but is it a good idea to have a spare prop on hand?? Do they really break that easily?. Mike is spot on. Bottom strikes, logs, submerged stumps, sand bars, etc will damage a prop. Have seen even a small amount of ripple on the trailing edge cause vibrations that will make a discerning boat owner notice a change in their boat.
The new one is lead in the rears. Loading the trailer with lead in the rears on a shallow angle ramp and the prop tags the flat stock on either side of the prop guard while loading and needs a prop rebuild after (and a touch up on the trailer paint).
I'd be looking at the 17x17 as a spare unless your really love your prop now. That way if you go to a big lake you can get around on the top end and hopefully save on a bit of fuel. Just may slip and blow bubbles a bit out the hole when weighted. YMMV, I'm used to propping boat for higher elevation.
Oh ya, dont forget to get a puller for the 1 1/4 shaft. I think it's the Acme 330S. The standard 1 1/8" puller that comes in most weekend saver kits wont cut the mustard.Last edited by freeheel4life; 05-01-2019, 04:54 AM.
