How often are you changing your Marine Power G force fuel filter/water separator? I have been replacing every fall but wondering if it's necessary to change this often. It's kind of a pain to change. I do run regular gas station up to 10% ethanol fuel but I add Marine Stabil every time I fuel up.
Also, do you need to add fuel to the canister before you install the new filter. I didn't do this last time and is seemed to work ok.
Bummer that it's winterizing season already.
