I figure I will put this out here for posterity. Because I can't leave well enough alone I built a surf gate this past weekend. I only got to run it in one configuration and I have some questions that I am hoping some of you can answer to save me time messing around with it (cause I'd rather just surf!). I have a 2001 2300v, perfect pass, FAE and surf flap. My listed setup is a custom bag in the port locker/under seat = 1470 lbs, bow bag with starboard leg rolled under = 300+ lbs, and a 400 lb bag in the bow walkway. I have been stoked on the wave this setup produces... but, well, you know
Here is what that gets me:
Speed of 10.5, taps at 6.
I was hoping to eek out a little more pocket with a gate as others have noted. Nothing more really, we have no major issues with running a listed boat. Not sure that a gate will really achieve this but I just had to try. So I built one. Its 22" long and 13" high and extends above the platform about 2" and below the spray pocket about 2". It is sitting at an angle of 22 deg from the swim deck. Looks like this:
So I ran this gate with the ballast setup listed above this weekend. You can see its effect on the offside in the picture below. The steering was horrible! The wave face was super clean but the wave was certainly less steep than without the gate. The boat had to work harder (higher RPMs) to maintain speed (cause there is a honking gate hanging off the back of course!) I think (maybe wishful) I gained a little bit of depth in the pocket but not enough to justify the horrible steering. Did I mention the steering was horrible? Here is the result:
Speed of 10.5, taps maxed out, approx same conditions as previous wave pic.
I am now thinking to make the gate adjustable to see if there is a setting where I get results and the steering does not suck so bad. Any input on an angle of deployment? Seems like if it was reduced it would improve the steering. Or perhaps it should not extend below the spray pocket? I am also curious about running significant offside weight to make the weighting more equal (This I will try on the next outing). However it would seem if I did that it would engage the gate more and increase the negative effect on the steering? Finally, am I just chasing my tail here? NSS style? A newer boat is not on the horizon but tinkering sure is fun
Cheers!
Cheers!
