Port Side Ballast dumps as soon as it is full???
    Just wondering if anyone else has had this problem. As soon as the port side rear ballast is full it switches to drain and I have to manually stop it. Also my taps system keep setting itself back to 1. Any advice?
    If you are using the Tige presets it does that to prevent air locking in the ballast line and then refills and dumps a couple times and then stops. The taps also resets to one when going back to get the rider and then after you take off moves to the preset setting to reduce the strain on the. motor when starting out.
      Thanks for the info!
