The scene:
Surfing along normally. Rider falls, circle back and shut boat down for rider change. Start boat back up, shift to forward gear, driveline clunks and motor dies. WTH? Try again, same. Jump in, Check prop for entangled rope or something, nothing there. Check tranny fluid level; good. Couple more tries, which I am certain is dumb, same result. Get towed in, get under boat to look, nothing fishy there.
While on hoist, motor off, prop turns 45 degrees by hand then HARD stop. Happens both ways, back and forth. Unsure if a neutral boat does this or what problem this indicates? Before this had never hand turned prop. I am sure this is likely not good!
No fluids in bilge that I could see. V drive? Tranny? What fails like this?
Completely normal up until attempted restart.
Chime in all the experts! Please!
