That is a GREAT wave! Do you remember what specs you were at as far as ballast weight, taps, and speed were?
Bow had close to 800#, 400# on top and no matter what sac you have under the seats you are limited by area there, when the cup holders pop out your good. 1000 or 1100# in the back. I got it from chp so I bet you have the same one. When it's full your locker hatch should be up about 6-8", and it should pop out those cup holders on the rear floor. Taps was normally at 8 if I remember right and I normally went 10.8 mph on the goofy side. On regular I ran the same weight but 11-11.2 mph and taps around 4-5.
In that one pic of yours the guy sitting on the transom needs to move over to the surf side. That right there will screw up your wake. Position your crew, Dial in your wake and do not allow them to move while you are riding.....
If you want to borrow my fly high bow sac come and get it
I have a sac in the bow under the seats. Not much point in changing that one because it is as big as the space! If memory serves me correctly I had nobody in the bow. I need to move some people up front and everyone else to right side. Sounds like I have some experimenting to do!
2008 Tige Z1 Limited Ronix Edition
360 hp, Fly High ballast, Alpine, JL Audio, Kicker, Wetsounds audio
It's great to talk to someone who had same boat as me. When I slid the zac into the starboard side I blew it up with air with pump just to get it stiff to force it all the way up front as far as it would go. My question is did you remove the cooler from yours? The cooler sticks down quite a ways under that seat right behind drivers seat. I love having the cooler there for cold ones and really don't want to take it out!
